Carb Cleaning = Varsol???
16K views 15 replies 7 participants last post by  joko
fjman said:
Dipping the entire assembly is usually reserved for berryman's, and if you dip anything rubber, kiss it goodbye (including diaphrams, float seats, and orings...)
You already have them off, right? Spend the extra time and do it right! Take EVERYTHING apart (keeping good notes, btw) and clean it all.
You've got the float height, the float needle arrangement, the emulsion tube, the needle, the slide assembly, the idle mixture setup, the choke feed, the choke plunger to worry about.... may as well tear it all down to the basics and worry about it all WELL, yanno?
Breaking down carbs sucks, but having to do it twice sucks more :D
Word, Just disasmble and clean them.
