1 - 17 of 17 Posts
Here are some parts I have from a 06-07 non s model?
Mirrors and license plate will fit other years.
The gauge cluster is $125 firm and from the 03-05 R6 which may also work on the S model?
The complete upper fairing and screen as pictured is $160.
Have an 06-07 R6 Ohlins radial mount Brand New with all mounting hardware and manual for the 2006-2008 non-s model. Price is cheap at $365 firm. That is a $100 off...
http://www.oppracing.com/show_product/5833-scotts-stabilizer-kit-yamaha-r6-2006-2007/
The 3" CRG Lane Split Folding Bar End Mirrors (same company that makes the trick levers) are the best folding bar mirrors around. I use them and I'm just crazy about them. Lockhart sells them for $90 each and more often than not they are out of stock because they are very popular and they don't seem to order enough. I want $160 for the pair firm and they are brand new. I also have special Rhino bolt on bar ends that are specially designed to hold the CRG mirrors for $55 a pair. Rhino sells them for $60. If you do not use the Rhino bar ends you will need a spacer for the mirrors to mount to and a longer bolt for the OEM bar end but be careful. I tried moulting the CRG with a spacer and the OEM bar end but after loosing one mirror on the freeway I decided to use the Rhino bar ends and never had a problem since.
http://lockhartphillipsusa.com/ Search Mirrors...
If you buy the mirrors I can get you a pair of aluminum block off plates for $25
See the photos here:
http://photobucket.com/R6Parts
If anything is of interest let's talk by phone.
PM me your telephone number for a quick call back.
to be honestly with you i think you can make the gauges say the exact milage yours has. you turn the bike on with your gauges hooked up and then unplug and plug the new gauges in and it should change. ive herd this works on gsxrs and was told it did for yamaha but i have not tried it yet
Might work with GSXR's but not R1's & R6's. I have tried it and what ever the cluster says is what it will always say. Plugging it in and out of different bikes will do nothing.
Free Shipping!
17K miles
1 - 17 of 17 Posts
