Hey all,
hoping someone can help me out here...
I have an 06 R6S with electrical problems (ER_1 reading on the gauges). Problem is, i bought the guages and lockset off ebay which are apparently off the US model R6S and are NOT compatible with the ECU on the canadian R6S. So, I'm hoping someone has the canadian parts i need.
Please PM me here if you have anything i can use...
thanks
Sam
Here are some parts I have from a 06-07 non s model?
Mirrors and license plate will fit other years.
The gauge cluster is $125 firm and from the 2005 R6 which may also work on the S model?
Have an 06-07 R6 Ohlins radial mount Brand New with all mounting hardware and manual for the 2006-2008 non-s model. Price is cheap at $365 firm. That is a $100 off...
http://www.oppracing.com/show_product/5833-scotts-stabilizer-kit-yamaha-r6-2006-2007/
The 3" CRG Lane Split Folding Bar End Mirrors (same company that makes the trick levers) are the best folding bar mirrors around. I use them and I'm just crazy about them. Lockhart sells them for $90 each and more often than not they are out of stock because they are very popular and they don't seem to order enough. I want $160 for the pair firm and they are brand new. I also have special Rhino bolt on bar ends that are specially designed to hold the CRG mirrors for $55 a pair. Rhino sells them for $60. If you do not use the Rhino bar ends you will need a spacer for the mirrors to mount to and a longer bolt for the OEM bar end but be careful. I tried moulting the CRG with a spacer and the OEM bar end but after loosing one mirror on the freeway I decided to use the Rhino bar ends and never had a problem since.
http://lockhartphillipsusa.com/ Search Mirrors...
If you buy the mirrors I can get you a pair of aluminum block off plates for $25
See the photos here:
http://photobucket.com/R6Parts
If anything is of interest let's talk by phone.
PM me your telephone number for a quick call back.
