Are the older model three spoke rims compatible with the newer 03-05 model R6 or is the 5 spoke wheel the only fit?
Discussion Starter · #2 ·
does anybody know?:(
good question to find the answer do this:
look up the specs for a 99-02 model and it will tell you rim size
then look up specs for a 03-05 model, it will tell you rim size
from there compare and get your answer
i would do it but im lazy lemme know what you find out!
Discussion Starter · #4 ·
Rim sizes did not change. 17x3.5 front, 17x5.5 rear. Now I wonder if the brake rotors and everything else will bolt the same. ??????:confused:
