G
Guest
·what are the differences between the r6 and the yzf 600 besides looks?
Engine
2004 YZF-R6
2004 YZF600R
Bore x Stroke
65.5 x 44.5mm
62 x 49.6mm
Carburetion
Fuel Injection
36mm Keihin CV Downdraft Carburetors (4)
Compression Ratio
12.4 1
12:01
Final Drive
#530O-ring chain
O-ring chain
Ignition
Digital DC-CDI
Digital TCI
Transmission
6-speed w/multi-plate clutch
Type
600cc, Liquid cooled, 4-stroke, forward inclined inline 4 cylinder, DOHC, 16 valves
599cc, liquid-cooled, 16-valve, DOHC, inline four-cylinder
Chassis
2004 YZF-R6
2004 YZF600R
Brakes/Front
Dual 298mm floating discs w/4-piston calipers
Brakes/Rear
220mm disc w/ single-piston caliper
245mm disc w/single-piston caliper
Suspension/Front
43mm telescopic fork w/adjustable preload, compression and rebound damping; 4.7" travel
41mm telescopic fork w/adj. preload, compression and rebound damping; 5.1
Suspension/Rear
Single shock w/piggyback reservoir and adjustable preload, compression and rebound damping; 4.7" travel
Single shock w/piggyback reservoir and adj. preload, compression and rebound damping; 4.7
Tires/Front
120/60-ZR17
120/60-ZR17
Tires/Rear
180-55-ZR17
160/60-ZR17
Dimensions
2004 YZF-R6
2004 YZF600R
Dry Weight
357 lbs.
412 Lbs.
Fuel Capacity
4.5 gallons
5.0 Gallons
Height
42.9"
46.9"
Length
79.7"
81.1"
Oil Capacity (with oil filter change)
2.85 Qt.
3.07 Qt.
Rake (Caster Angle)
24.0°
25.0°
Seat Height
32.3"
31.7"
Trail
3.4"
3.82
Wheelbase
54.3"
55.7"
Width
27.2"
28.5"
Other
2004 YZF-R6
2004 YZF600R
Color
Team Yamaha Blue/White; Liquid Silver w/ Flames; Rapid Red
Gear Ratio - 1st Gear
37/13 (2.846)
37/13 (2.846)
Gear Ratio - 2nd Gear
28/18 (1.556)
37/19 (1.947)
Gear Ratio - 3rd Gear
28/18 (1.556)
34/22 (1.545)
Gear Ratio - 4th Gear
32/24 (1.333)
28/21 (1.333)
Gear Ratio - 5th Gear
25/21 (1.190)
25/21 (1.190)
Gear Ratio - 6th Gear
26/24 (1.083)
29/27 (1.074)
Jet Needle
Not Applicable
#1,4: N3FC #2,3: N1YF
Main Air Jet
Not Applicable
#80
Main Jet
Not Applicable
#155; CA mdl = #148
Needle Jet
Not Applicable
2.6
Pilot Air Jet 1
Not Applicable
#140
Pilot Jet
Not Applicable
#38
Pilot Outlet
Not Applicable
0.9
Primary Reduction Ratio
86/44 (1.955)
82/48 (1.708)
Secondary Reduction Ratio
48/16 (3.000)
47/15 (3.133)
Warranty
1 Year (Limited Factory Warranty)
MSRP
$8,099 (Blue; Red)
$8,199 (Liquid Silver w/Flames) All available from October 2003
$7,099* Available from July 2003
finally someoen with some sense! the yzf600r may not be an all out track scratcher or have 100+ HP dyno's but it's not made for that!! it's not an all out track bike like the R6 is. Each bike has it's purpose. It's kind of like comparing 2 different types of cars. one made for gas mileage,touring, and passengers. The other made for high speed turns, unreal acceleration, and bad ass looks. I have a 600r and I love it. my roomate's got an R6 and he loves it too.Tin PusheR6 said:Hey, I had a YZF600R Thundercat when I lived in Japan, and I still think it's a great bike! It doesn't look as cool, or handle quite as well as the R6, but it's still a great all around bike. Light years ahead of the Can-O-tuna anyway.
deftdrummer said:finally someoen with some sense! the yzf600r may not be an all out track scratcher or have 100+ HP dyno's but it's not made for that!! it's not an all out track bike like the R6 is. Each bike has it's purpose. It's kind of like comparing 2 different types of cars. one made for gas mileage,touring, and passengers. The other made for high speed turns, unreal acceleration, and bad ass looks. I have a 600r and I love it. my roomate's got an R6 and he loves it too.
😂😂😂😂😂😂😂the R6 is made for hauling ass :burnout the yzf 600 is made for hauling two asses :smokin :sexy but don't get me wrong, the R6 can pull some quality tail...just make sure she's under 150 or every time she leans over to scratch her ass you'll be dragging an unintentional knee in your jeans... but yes, both are good bikes...it just depends on what kind of riding you want to do....the katana thing is pretty accurate.......... oink
