1 - 12 of 12 Posts
I've got a 2000 r6 and would like a longer swingaarm. Not alot just a little. Is it possible that another Yamaha swingarm could be used to do this. For example The watercooled 750 gsxrs came with a 1" shorter swingarm than the 1100. You can use the 1100 arm and noone can tell it's extended. I would like the bike a little longer for this new motor I am building. But I don't want to weld blocks into the arm. Anybody know if maybe a R1 arm would work if it's any longer?? Something to that effect is what I'm looking for...
any spacers you need for the 03/04 swing arm swap? or is it just simple bolt on, u can use the the 02 wheel n rotor correct but gotta use the 03/04 caliper and shock?
Discussion Starter · #6 ·
Thrak said:
you need a new swingarm because of a motor? :umm
03-04 R6 swingarm is 10mm longer than 99-02.
Yeah I'm doing a little engine build and would like to make the bike a little longer without drawing attention to the fact that it has been extended.
Hi , How are ya
Negative
The wheel doesnt work on 03-05 03-05 you can make work on 99-02:thumbup
1 - 12 of 12 Posts
