I have a 2000 R6 that I use for track days and occasional races. I am trying to check suspension setup. It has a penske rear shock set at 310mm from eye to eye. Does any one have ideal numbers on the height on the front forks and the rear end setup?
I am running pirelli supercorsas.
Thanks in advance
I sell money
depends if you have had front end work done as well... with the Suspension Solutions/Traxxion dynamics front end and 10mm fork tube extenders I had... 32mm seemed to be a good starting point, but I used michelin PR's... not sure on the pirelli's! If you give Lithium (see below) a call and ask for ryan he may be able to help ya! I'm not sure what the profile difference is between the 2 personally.
good luck
Tim
