Hi all,
I've been posting this issue on another forum, but I'm really getting to the end of my rope and thought I'd see if anyone here can help. Here's a (not so brief) summary of the bike's behavior and what I've done.
2005 R6 ~ 9,000 mi
Bike surges at idle and sometimes when I've been riding for while or revving hard, it will surge through such a wide RPM range it just dies. I've looked at numerous things and can get the bike to idle perfectly if I unplug one of two sensors, the Intake Air Pressure sensor or the Atmospheric Pressure sensor.
The old Intake Air Pressure sensor tested ok as per the service manual, but I replaced it anyway, thinking that would fix the problem. Nope. Then I tested the Atmo sensor and it tested out of range high on the multimeter. I just received a replacement today (taken off a 2008 R6S, same part number), and it doesn't fix the issue either.
The vacuum at the intake sensor shows to be almost the same as at the #3 throttle body takeoff. Slightly higher, so I don't think I have a vacuum leak. I also think if I had a vacuum leak, unplugging those sensors wouldn't help at all. I mean it's like a switch. Sensors connected, idles like crap. Sensors disconnected, idles great.
Anyone have any ideas?
Chris
2005 R6 ~ 9,000 mi
Chris
