are the tires ballanced?
ya, if they're flush (i.e. no fork tube showing), then the front hasn't been dropped (i.e. stock height).bballman01 said:how far the forks stick out from the top of the yokes^
why not raise the forks?eventnick said:shim the rear, leave the triples be.
__________________You're wrong... dropping the forks *might* be easier, but bringing the rear up will not only increase mid-corner stability, but it will also be just as flickable.
Dropping the forks 8-10mm kills your front end feedback, and decreases stability...
Ok, so I understand that it adds ground clearance. Is that really an issue with our bikes? At what point does one need more ground clearance? Will it help clearance when leaned over? How close does one have to be on the edge of traction to needing the small amount that will be added when leaned (because it'll be a fraction of what is added when upright, right?)?eventnick said:From the Almighty Thrak
It also gives you added ground clearance, its really really easy to do, easy to change and experiment with and you dont have to make sure that each fork is 100% the same which is a pain in the ass.
