Slip-on a little loose..
438 Views 3 Replies 3 Participants Last post by  Stryker
I put on a Termi slip-on about 2 months ago. The can has come a little loose (I can move it side to side slightly) from the midpipe. I was told secure it with some high temp silicone. Went and grabbed some thats good to 315C (600F). This should do right?
did you check the fastner bolt first? maybe that came loose.. and how far down did you put the pipe onto the header pipe?
My termi's the same, never did sit real tight.. But not loose enough that it moves around any amount by itself..
The fastener bolt seems tight enough. I don't think my pipe would move on its own either, but I'd like it to be secure enough that I can't wiggle it around.
