Invisible from the outside, the Sena 10U Communication System is a built-in system that allows you to talk with up to four people within 1.6 kilometers thanks to Bluetooth Technology. You can also listen to your favorite radio station by activating the integrated programmable FM tuner.
The Bluetooth Handlebar Remote is easy to use with gloves, allowing you to focus on the road rather than the device. The 10U is equipped with special noise control that blocks out distracting sounds such as wind, while still allowing you to be aware of your surroundings.
MSRP$299.00
The Sena is easy to install, so you don't have to send your helmet out. The Sena 10U is available for the following helmets:
Shoei GT-AIR
Shoei Neotec
Schuberth C3/C3 PRO
All Arai Full Faced Helmets
Pictured above is the Sena 10C, an external communication system. As you can see, the external system looks much different than the Sena 10U, which is pictured below.
Pictured above is the Sena 10U installed on a Shoei Borealis Neotec
If you have any questions about the product or would like to place an order, feel free to give Brad a call at 866.931.6644 ext. 810. Is email more convenient? Send us a private message through this forum or write to us at FORUM at RIDERSDISCOUNT dot COM, and we'll get back to you right away![/FONT]
