1 - 9 of 9 Posts
VSISAPUNKBITCH!
use a dremel to get the rivet out, cut it with bolt cutters, plasma cutter, hack saw, just any way you can cut it off.
If you're removing it you must be replacing it right? Just cut it off.....I think the only other way is to remove the whole rear swingarm.
You can get another master link for it, but you'll have to either cut it, or you can take both the front and rear sprockets off......I'd cut it, but if you are 100% dead set against cutting, then you'll be taking the rear wheel, fairings and sprocket off to get it out intact.
Discussion Starter #9
yeah there is no way to get it off without cutting it... it goes through and around the swingarm ... even taking the swingarm off you still have to cut it.
1 - 9 of 9 Posts
