So I got into a pretty bad wreck during my last race weekend.
I got everything put back together. I use the bike for racing and commuting. So I need the fan on my radiator. So day I finally finished everything and wanted to see if my fans worked. I got the water temp up to 205-210 and then I shut the bike off because I wanted to see if the fans would turn on.
So when I do that only the right fan turns on. Is it suppose to do this? I don't remember if both with on or just the one with on before. Does the second one kick in only when the motor is running or whats the deal with it?
I tested the both fans with a 12 volt battery and both of them are fine.
Discussion Starter · #2 ·
never mind. I found out the fuse was blown.
