· Registered
I’ve recently replaced my blown motor that had a hole in the block with an fz6r block I found for a good price. I literally used just the block from the fz. So I threw the throttle body back on and everything how it would’ve been on the r6 block. I read the way the firing system works is diffrent and it is so I swapped the head cover so I could keep the system the same and use the cam sensor. I finally got it ready for a first start and it cranks, but doesn’t turn over. Fuel pumps are working and it’s everything but the ignition system. It also flashed a check engine light I have yet to scan for. Any tips to get it started?
