Hi
Bike is not starting even when trying to bump start. Battery is brand new, checked fuses and switches, starter relay is working fine - checked with multimeter. All lights go on as usual and no fault codes come up.
That leaves me thinking that it has got to do with either fuel reaching injectors (injectors were serviced and just put back in) or spark plugs. Checked the fuel flow and seems fine however do not have pressure gauge so cannot be sure of sufficient psi.
So, I can try to check spark plugs and coils first (annoying job to do) or change fuel pump first and bet that’s the problem.
Any thoughts or suggestions are welcome.
