Garage Queen R6
It will work if you get all the necessary parts. This includes R1 triple tree, clip ons, fender, and forks. Look for the R1 fork conversion in the How-to section and it explains all you need to know.
its a pretty easy swap, all you have to do is swap stems and shim your calipers. if your going to streetfighter it you will need longer cables and brake lines.
OH......IO
if you do a search the topic has come up many times. i have this set up on my bike now. i did buy the full set up from YamRZ350. the set up is 01 r1 forks, 01 r1 lower clamp, 02 r6 stem, 05 r6 top clamp, 02 r6 clipons, 06 r6 front wheel, 02 r6 brake calipers, 03-04 r6 brake rotors, 02 r6 brake lines, 01 r1 front fender and everything else from an 02 r6. i have an 02 r6 if you have not already inferred. the brake lines from the 02 r6 will work, but you will not be able to put the through the bracket that holds them and the cable also will work. if you read the how to its a good place to start.
