Put ZX10 Front end on R6 (pics)
only took me 4 hours! i have the whole front end, clamps, forks, wheel, and brakes. the biggest problems i have run into so far were 1. the bearings are larger on the kawi and 2. the stem is about half an inch shorter on the kawi. to solve the bearing problem, all i had to do was swap the bearing races. this accounted for about 3 hours and 45 minutes of the entire process... they were some beyatches to get in an out. once they were in the steering stem problem had to be delt with. everything is put together and is snug and firm, no rattle slop or play whatsoever. my only concern, and it may indeed be small, is that instead of having the nuts underneath the top triple clamp putting pressure on the head bearings, there is only room to put the top clamp on and then the nut that goes on top of that. So basically, the nut on top is now doing what the nut on the bottom (of the top clamp, closest to the top of the frame) was doing. i plan on safety wiring this or allowing for a cotter pin type deal there just to make sure the nut doesnt loosen up on me. other than that, the forks look sweet and i will post pics as soon as i get the clipons and controls worked out!:thumbup
