Power wire
528 Views 1 Reply 2 Participants Last post by  saefirebird
I'm sorry for this this newbie question. But, I'm hooking up my speedohealer on my 01 r6, and I'm looking for a wire that I can tap into for power, I don't have a multimeter, so I can't test for one, and I really suck with electronics. Does anyone know of a wire under the gas tank that I can tap into for power?
Thanks:hattip
Follow the wire for your rear brake switch up to where it plugs in (UNDER THE TANK). It is a brown connector. The two wires are both black going up to the plug, then on the other side of the plug (on the main wiring harness) the wires are brown and yellow.
If you splice into the black wire that connects to the brown wire, you'll be good to go.
