Hello all, I am in need of your expertise here! I was riding on the highway today and I heard a very loud pop noise, immediately my bike stopped accelerating and lost power. The speedometer and tachometer are blank, like it has no power going to it. The headlight turns on but that’s pretty much all the power I can see. I pulled over and tried to turn the key to the off position and turn it back on but that didn’t help. The bike was leaking oil so I took it to the shop yesterday and they changed out a bolt in my clutch cover that had cracked the case from the inside a little bit. They put some kind of seal around the clutch cover and made the bolt thread bigger and put a new bolt on the bike. What could be the issue? It’s a 2002 R6 with 24,000 miles.
Hello all, I am in need of your expertise here! I was riding on the highway today and I heard a very loud pop noise, immediately my bike stopped accelerating and lost power. The speedometer and tachometer are blank, like it has no power going to it. The headlight turns on but that’s pretty much all the power I can see. I pulled over and tried to turn the key to the off position and turn it back on but that didn’t help. The bike was leaking oil so I took it to the shop yesterday and they changed out a bolt in my clutch cover that had cracked the case from the inside a little bit. They put some kind of seal around the clutch cover and made the bolt thread bigger and put a new bolt on the bike. What could be the issue? It’s a 2002 R6 with 2i
