1 - 20 of 28 Posts
Parting out a 2005 Yamaha R6 Race Bike. Most parts will fit 2003-05 Yamaha R6. I have pictures of some items and will take more tomorrow. Email me at [email protected] for pics or call me (Andrew) at 323.244.8756. Located in Los Angeles.
Performance/Racing Parts
Graves Full Ti Exhaust with Oval Silencer, Black Graves Exhaust Hanger and clamp (straight, clean, 8.5 out of 10) $500
Graves Full Ti Exhaust w/ Oval Silencer (straight with some very minor dings/dents to the can, graves sticker missing) $350
Ohlins Rear Shock - Model #46PRXS, Model #YA305U, supposed to fit 03-04 R6, but was on my 2005 and worked perfectly (excellent) $650
Full Front Suspension (forks and triple clamps) Traxxion Dynamics AK-20 Cartridges and 0.95 Springs (180 - 200lb rider) (straight, lower triple stop is tweaked a little, few nicks in various places) $800
GPR Steering Stabilizer (works perfectly, on of mount holes at tank slightly out of round because I had to drill out fastener) $225
Vortex Adjustable Rear Set, right/brake only, black (slight rash at end of peg) $125
Graves non-adjustable Rear Sets, silver w/ black pegs (excellent condition except rash at tip of brake lever) $100
Graves non-adjustable Rear Sets, black (brake side has rash at tip of lever, shifter side is bracket only - no shift lever or peg) $50
Power Commander III w/ USB (2005 only) - includes software and patch cable $175
Quickshifter (PUSH - wear on side from accident, sent to Dynojet for inspection - fully operational) $125
Quickshifter (PUSH - excellent condition, slight wear on side were it rubbed frame, sent to Dynojet for inspection - fully operational) $175
Pazzo Brake Control, Black/Black - shorty (rash from 5-mph tipover, straight) $50
Pazzo Clutch Control, Black/Black - shorty (perfect) $75
Hinged Clipons, black - make unknown (very nice, few minor scratches, no rash) $125
Graves, quick release fairing bracket (been down but straighted out - one break in center support behind speedo bracket does not affect performance) $50
Vortex Gas Cap - Black Base and Cap (perfect) $75
Stainless Steel Front Brake Lines with banjo bolts, red (excellent) $50
K&N Air Filter (excellent) $35
AK Composites full race Bodywork - Upper, Lower, Front Fender, Superstock Tail, no undertail (fender is for 03-04, can sell with a different 05 fender if interested) $350
Sharkskins Lower (few scrapes from 5 mph tip over in gravel) $100
Valter Moto Superbike Tail with undertail (few scrapes from 5 mph tipover, one fastener hole in undertail broken - still works fine with 3) $150
Sharkskinz Superstock Tail with undertail, blue w/ yellow numberplate (excellent condition) $150
AK Composites front fender, 2005 only (solid, normal wear to paint for front fender) $35
LP V2 Clear Double Bubble Windscreen (New in bag) $45
Hotbodies Clear Windscreen (New in bag) $35
Vortex two-piece frame sliders (rightside has abrasion from 5 mph tipover, no mounting bolts) $30
LP Swingarm spools _(excellent condition, with mounting screws) $10
Factory Pro SuperFlare Velocity Stacks Installedin Factory Airbox $100
DID 520 ERV3 Chain 118 Links plus new Master Link (used 5 days) $50
2005 R6 Service Manual $30
Exhaust hanger, black $15
K&N Oil Filter, KN-303 (new) $5
Stock Parts
2005 frame w/ Clean CA Title (straight, some scratches, broken tab where black plastic side cover mounts) $600
Wheel Set '06, Raven - from a racebike, so normal race wear (includes all rotors (3), cushdrive, and sprocket carrier, axles & spacers) $400
Front Wheel, '05 (includes rotors, spacers, axle) $225
Rear Wheel (inlcudes rotor, cushdrive, sprocket carrier) $175
2005 motor - 108.4 hp at rear wheel (have dyno sheet) comes with NRC stator cover and Graves Engine Cover (20 days on motor since rebuild in late 2006) $700
Rear Subframe (95%, went down in lowside and has crack in thin crossmember) $75
Rear Subframe (looks almost new, 9.9 out of 10) $125
Tank w/fuel pump,no damage, clear Stomp pads, painted in two-tone burgundies (no gas cap) $150
Tank w/fuel pump, primer, stock gas cap which has been drilled out (ding the size of a pencil eraser and a few light scratches) $75
Ramair tubes (been down but good condition, will bolt up straight) $25
ECU (perfect) $100
Rectifier (perfect) $30
Speedometer (everything works, some discoloration on underside, shows 13,325 miles) $100
Master cylinder, stock brake lines (excellent) $50
Throttle Bodies (excellent) $50
2005 Radiator with fans and all rubber tubing (excellent) $75
2005 Radiator w/ cap (excellent) $35
2003-04 Radiator (very good, no cap) $25
Swingarm, screw for captive axle block on left side (rash on left side from lowside) $25
Swingarm, scres for captive axle block on left side (slight wear from boot)) $35
Rear caliper, master cylinder, held captive to axle block for quicker wheel changes, no reservoir - line plugged (excellent condition) $25
Front Calipers (excellent condition) $40
Rear fender (very good condition) $15
Clutch handle perch (excellent condition) $25
Complete wiring harness and undertray minus headlight harness, fuel injection, and battery ground harnesses (looks almost new) $65
Complete wiring harness (used from racebike) $50
Stock Seat (excellent condition) $25
Stock silver front fender, silver (solid, but has some scratches) $15
Discussion Starter · #5 ·
Shipping would be $45 for DHL ground. It doesn't weigh that much, but its a big box to get both the subframe and tank in. I only have the painted tank left (sold the primered one).
I'll need your email to send you pics of the rearsets.
Thanks,
Andrew
Discussion Starter · #12 ·
UPDATED - Parting out a 2005 Yamaha R6 Race Bike. Most parts will fit 2003-05 Yamaha R6. I have pictures of some items and will take more tomorrow. Email me at [email protected] for pics or call me (Andrew) at 323.244.8756. Located in Los Angeles.
Vortex Adjustable Rear Sets, black (excellent condition) $225
Stock Parts
ECU (perfect) $100
Discussion Starter · #15 ·
Updated 7/15/08 - Going on vacation tomorrow. No shipping until after 7/28/08
I take paypal. All prices do not include shipping, but shipping will be at cost. I prefer DHL ground or USPS.
Stock Parts
2005 frame w/ Clean CA Title (straight, some scratches, broken tab where black plastic side cover mounts) $600 SALE PENDING
2005 motor - 108.4 hp at rear wheel (have dyno sheet) comes with NRC stator cover and Graves Engine Cover (20 days on motor since rebuild in late 2006) $700 SALE PENDING
ECU (perfect) $100 SALE PENDING
Discussion Starter · #16 ·
Updated 7/29/08 - Back from vacation.
Stock Parts
Discussion Starter · #17 ·
Updated 9/03/08
AK Composites full race Bodywork - Upper, Lower, Front Fender, Superstock Tail, no undertail (fender is for 03-04) $350
Stock Parts
1 - 20 of 28 Posts
