I recently stripped down my '01 R6 in order to trouble shoot an ignition problem. I found that the throtle position sensor was giving off bad readings so I cleaned it in Acetone. Anyway, so i pop the sensor back on and adjust it, then hook up all the other conectors i unhooked; air box on, fuel tank, and all that. I crank it and it sounds all right. But then i rev it up to 6 thousand twice and on the second time the engine turns off! WTF? The engine will still turn over till im tired of turning it over, but there is no spark. I tested all the coils and they are all at 10.5k ohms to the chassis and the individual wires all check out properly to the cdi unit. The pickup coil reads ok(though I have no idea how to check if the signal is being sent). The cutoff relay tests bad but it tested bad before I cranked it so im not sure the manual has the right test info, and I can here it click open and shut when i raise/lower and pull/release the kickstand/clutch. Not to mention I can turn the engine over. This has me stumped, so I was hoping someone here had a clue as to why my bike won't give me spark all of a sudden.
