The problem started after I tried a clutchless shift from 1st to 2nd. The shift failed with a dreadful sound and from then on the neutral light would blink rapidly whenever the bike was in neutral.
Today the light went totaly dead. I removed the instrument panel and checked the LED. It is functional so the problem must be the neutral switch.
Where is the neutral switch located? Is it easy to change?
I found the problem. There are two big relays under the seat, right next to the battery. Some of the cables were broken. I soldered them back on and the problem was solved!
R6 Message Net
