1 - 7 of 7 Posts
My neutral light will not come on. No mods have been made and all my other lights such as highbeam and indicators are working just fine. Is there a neutral indicator system issue OR is it simply a busted bulb? if its either could you please give me any general description as to how to fix the issue. Dealers and shops charge an absolute fortune. I want to learn for myself
Thanks Alot
ok i looked at my manual and its on the back of the engine block near the rear suspension shock. looks like a tight fit... follow the line back to the connector plug and check for continuity there. It would be best to check with your gear lever in multiple positions just in case its not in neutral, or put it in a position where you can start your bike without pulling in clutch and that the kickstand down, that way you know it for sure is in neutral.
also make sure you check your "signal" fuse to make sure its not blown before you get in too deep.
1 - 7 of 7 Posts
