it is inbetween the gas tank and the seat. if you lift up the tank you should be able to see it. it is really easy to see. you dont have to lift up the tank to see it just look below the tank its right there good luck there is a really good howto on this forum that will help you.
unbolt it from the right side and remove the brake res, the pull it out and unplug. thats how I did it, use a socket wrench for the top and a open hand for the bottom as it is very close to ur rear suspension unit
