1 - 11 of 11 Posts
Still lots to do, but I'm getting there. :thumbup
I have a few questions...
I have the famous 2nd gear problem... I also have a spare 04 engine and a spare 99 engine (both gearboxes are fine). Which should I use? Can I fit the 04 box easilyenough?
What front end is best to fit onto the R6? I want USD's! R6-R? RR? R1? B1H?
Comments welcomed...
bike looks great... to bad about the 2nd gear problem, i had the same on my '00 I tore it down and replaced all the bad parts then put a GP shift rod on there so it wont come back.
by front end do u mean the forks and triple trees or the plastics, if u meant forks then yeah get parts from an R1 there is a how to out there.
later
"Z"
Discussion Starter · #7 ·
Took both my 02 R6 and the 04 R6 to my mates garage ready for the change. Both bikes were complete and ridable.
The 02 R6:
The 02 R6 and the donor 04 R6:
The 04 engine out:
Getting ready to remove the 04 gearbox:
The 02 engine stripped:
The problem:
Had a few snags but to strip both bikes, drop both engines, and remove both gearboxes in an evening is pretty impressive, I think!
The problem!
No gearbox in the 04 engine...
Engine going back in...
Nearly done...
Testing everything out...
All done. ;)
...and then to test the gearbox out I went through the box on the paddock stand (the clocks showed 196mph bouncing off the limiter in 6th).
Here's a video...
grimkeeper
Nice bike, lotts of work there.
1 - 11 of 11 Posts
