So I recently had a problem corrected from this thread: http://www.r6messagenet.com/forums/showthread.php?t=67164
Anywho, while I was installing some LED license plate lights, something happened when I was adjusting the plate because both LED's blew and now my left brake light/turn signal is stuck on. It is an integrated taillight with the same red LED's used for the turn signals (came with the bike).
Any ideas?
Discussion Starter · #4 ·
Problem solved! When I disconnected my front turns the other day (refer to other thread) I left 2 wires touching and this was the cause of the problem.
Also for the other problem (blowing the signal fuse), it was because the front flushmounts I installed were LED's. I replaced them with regular bulbs and everything is peachy now. What a relief!
