Lancee Perfector The best way to clean your skin from blackheads, inflammation and dead cells is a scrub. It is very important to choose the right product for your skin type so that it is effective. Properly selected scrub makes the skin clean and soft and deeply cleanses the pores. With regular use of this product, blood circulation can be normalized, the skin can be saturated with oxygen, which will make it more youthful and fresh. It is important to remember that scrubs cannot be used daily, as this can disrupt the balance of salt and water and thin the protective layer of the skin. Daily use of scrubs can dry the skin, which will lead to the appearance of irritations and various rashes. Determine your skin type on the basis of this, select the appropriate scrub and the frequency of its use. Holders of dry skin should be cleaned once every 2-3 weeks, owners of oily or normal skin can do this once a week. Oily and problematic skin requires more thorough cleansing, therefore large-sized abrasive particles should be present in scrubs for these skin types. They will help remove serious contamination and cleanse the pores of the subcutaneous fat that has accumulated in them. For oily skin, scrubs with sea salt or chopped fruit seeds are best suited. Look for products with cosmetic clay on sale, it well removes oily sheen and tightens pores. If you have very oily skin, you can use scrubs 2 times a week, but not more often. Holders of sensitive skin prone to irritation should pay attention to scrubs with chamomile flowers, tea tree extract, aloe, grape extract, mint leaves. Look for options with soft, fine granules that won't damage your skin. If you are a happy owner of normal facial skin, pay attention to products with moderately coarse abrasive particles. As part of scrubs ideally suited for normal skin, crushed coffee beans or loofah must be present.
