Envy Us Cream It is better to use a cream intended for the bikini line, or take it for sensitive skin - this will be less likely to get a burn. Apply the cream for 5-7 minutes (look at the packaging), then rinse and apply a nourishing cream. This is not a way to permanently remove hair; you will have to repeat the procedure weekly. Wax strips are also suitable for removing hair from the chin. But in order to save money, you can not use the entire strip, but cut a small piece from it. Firmly attach a wax strip to the problem area and sharply remove it against hair growth. Vegetation will appear soon, but it will grow back, so repeat the procedure as the hair grows. You can go to the beauty salon and have a hair removal with the destruction of the bulbs. The hair will not bother you anymore, but sometimes unforeseen situations occur and the hairs incredibly begin to grow again. If this happens, then soon, so you can safely perform a miraculous procedure. But remember, after it there may be minor skin burns, which should eventually disappear without a trace. Endocrine diseases, hormonal changes, chlorinated water, low-quality cosmetics, poor ecology - all this negatively affects the condition of the skin. As a result, the skin becomes inflamed, acne appears. When treating acne, home-made masks can be used. The main advantage of homemade acne masks is their natural composition.
