1 - 20 of 89 Posts
Well because I love you guys so much and I've learned alot of different stuff on this board, I thought since I tackled this job, I might as make a How To on it ;D So here it goes!
All this was done on an 2002 R6 so the socket sizes and torque specs are for that bike. You may want to confirm just to make sure. If I have anything incorrect or would like me to add, just let me know!
Tool Sizes = Bold
Torque Specs = Underlined
Remove Front Wheel
To remove the front wheel. Of course you need a front stand (which isn't picture because I took these pictures after I was done.
1 - Remove the brake hose holder bolt (#1) with a 8MM socket. Snug
2 - Remove the 2 caliper mounting bolts (#2 and #3) with a 12MM socket. 29 ft/lbs Remove the caliper and connect a zip tie to the upper hole where you just removed the bolt, to hold the caliper up. Do not let it hang by the hose!
3 - Repeat on opposite side.
4 - Remove the wheel axle pinch bolt (#4) I believe its a 6MM hex bit. 14 ft/lbs
5 - While holding the wheel, remove the axle (#5). Take a 3/8" spark plug socket from craftsman, remove the rubber boot inside and then use an extension to loosen it 52 ft/lbs
6 - When putting the wheel back on, just reverse the order and make sure to put grease on the axle.
Remove Rear Wheel
To remove the rear wheel, it must be on a rear stand.
1 - Loosen the locknuts (#1), Use a 12MM open wrench. Loosen it goes all the way to the right towards the adjust bolt (#2). Do on both sides. Snug
2 - Turn the adjusting bolts (#2) so they are all the way towards the front of the bike, the locknuts will be right next to them. Use a 12MM open wrench. Doing this will give the front wheel enough room to push foward to remove the chain. Do on both sides. Snug
3 - Remove the chain guard bolt (#3) with a 10MM socket. Snug Removing this makes it easier to remove chain from sprocket.
4 - Remove the other chain guard bolt, its directly behind the rear set bracket (arrow) with a 10MM open wrench. Snug Also remove the plastic philips clip, push gently, only a 1/4 turn to take it off.
5 - Remove the caliper mounting bolts (#4 and #5) with a 6MM hex bit. 20 ft/lbs Rest caliper on swing arm.
6 - Remove caliper bracket bolt (#6) with a 20MM socket. 29 ft/lbs
7 - Remove wheel axle nut, (#7) with a 32MM or 1¼ socket. 108 ft/lbs
8 - Push the rear wheel foward and pull the chain to the side, so if you were looking at the bike from rear to foward, pull the chain to the left. While pulling the chain to the left rotate the wheel slowly and the chain will come off the sprocket.
9 - Remove the wheel axle, make sure to lube when reinstalling.
Adjusting Chain Slack
To adjust chain slack, first make sure its on a rear stand, the chain is at its looses when there is no weight on the rear tire.
1 - First take a ruler and place it on the swing arm so it can not move. Your going to first want to pull down on the chain and mark where it comes to on the ruler. (1st picture)What I do is pull the chain down and put the ruler so the chain is at 6".
2 - Keep the ruler in the same place and now push up on the chain(2nd picture), the distance between the two marks is the slack. between 1.5" and 2.0"
3 - You may want rotate the rear tire and check the chain in a few different spots. If its different in all different spots, your going to want to adjust the chain slack to the tightest spot on the chain (least amount of slack)
4 - Loosen the axle nut, and caliper bracket bolt on the opposite side, (see above or below)
5 - If you need to adjust the slack at all, just loosen the locknut a little (#1), Use a 12MM open wrench and use the adjusting bolts (#2) until you get the correct amount of chain slack. Snug
Rear Wheel Alignment
Since I couldn't really find a good place with instructions on how to align the rear wheel, even the how to's with the string were not very detailed, so here is my version. Rear wheel is on a stand, front will not be.
1 - Get string (not fuzy stuff) or fishing line. What your going to do is take about 20 feet, and your going to wrap it around the REAR tire/rim once and have it go towards the front. Make sure its not in any grooves as this may mess up the measurments. Tie the pieces of string to something that will not move and can keep the string taut.
2 - You first want to make sure both sides of the string are JUST touching the outter most foward part of the tire. The (blue line) is the part of the tire that sticks out the most. Make sure its just touching it.
3. Leave the tools or whatever you use to hold the string in place, if they are just touching the outter most parts of the tire, you are perfect so far. Now you must measure from the outter most of the front tire (blue line around tire) to the string, both on the front part of the tire and on the rear(arrows).
3. Say the brake sides measurments of both front and back on the front tire must be the same, and the clutch side measruments of both front and back on the front tire must be the same. Brake and clutch do NOT had to match at this mount, just the front and back of each side. Nudge the front tire until the measurements are the same.
4. Now that the measurements are the same, what your going to do now is find out which side has more of a gap between the string and the front tire. Say your looking at your headlights and the left side has more of a gap, what that means if you have to loosen the rear axle nut (#1)32MM or 1¼ socket. 108 ft/lbs and the caliper bracket bolt (#2) 20MM socket. 29 ft/lbs only loosen them enough for the rear tire to move backward and foward, do not remove them.
5. Next your going to want to loosen the locknuts (#4)to the right of the rear axle nut. Use the adjusting bolts (#3) to either push or pull the the rear tire in the direction you need. Do not use the clutch side adjusting bolts, because this will mess up your chain slack.
Your post comes rite on time. I was just doing some research how to take off both wheels. Thanks for the time you spent on this. Much appreciated!
WOW, Bravo! :handclap You did a great write up! I am going to be putting a new rear on soon and this helps me a ton!! THANK YOU!!! :smilecool
Who's Ya Daddy???
Why do the caliper and hose bolts need to be removed if your removing the front wheel?. Won't it just drop out once the axle bolt and rest has been removed?. Just curious. Nice write up:badger
Member
Great write up.
Just an FYI, you don't NEED to loosen the chain adjusting bolts to get the chain off. If you plan on adjusting the chain anyway you can do this but if you take the axle out first you won't need to change the position of the bolts.
Once the axle is out just lift the wheel up a little and rotate it so the chain comes off.
For 03/04 owners:
Front wheel axle spec is 66ft/lbs
All 4 front pinch bolts are 13ft/lbs
Rear axle bolt is 80ft/lbs
Good job :thumbup
Any suggestions on holding the front end up when you remove the front tire? I've only got one stand and its for the rear. Will a plain old hydraulic jack under the forks suffice for holding the front end up while the tire is off the bike?
Fire Fighter/EMT
When I did mine I used a regular car jack and a wooden board. put the wooden board under the headers and used the car jack to lift it up. there should be a flat metal plate under the headers. aim for that place when putting the board and jack under the bike.
oh yea.. i did this using stock headers.
Ok, once I get the front wheel off...
What do I do with the bike? With the bike on the jack it is PRECARIOUSLY balanced. One fart and that sucker is gonna tip over. I do not have a front stand.
Would it be safe to let the bike down and allow it to rest on the forks (assuming I put a piece of carpet down or something)?
Thanks
Discussion Starter #19
Thanks
uhm, i wouldn't suggest it, i'd suggest putting up the money for a front stand imho
1 - 20 of 89 Posts
