When I hit the highbeam switch on my 00' R6, both lights turn off. When the highbeam is off, the lowbeam/left side is on as normal. Is the right side bulb burnt out? or is there a wiring problem?
have you replaced the bulbs before?? if you have not replaced them before then that is what i would do first. if you still have the problem then start trying to figure out a wiring issue. but making sure that your bulbs are good is the first issue to solve.
for the first gens
both lights should be on all the time, none of this new bike stuff where one is high beam and the other is low...
we have dual filament bulbs, so just replace your bulbs and you'll be fine
Hey guys, I just saw this thread. I was having the same problem and about 20 minutes ago I replaced the bulbs, but hitting the high beam switch still cuts out all light...low beam is fine. Any ideas what else to check?
