Anyone know where this came from??
Found it all chewed up sitting on the bottom part of the rear swingarm. Looks like it got in the chain at some point.
This came off of my 2001 R6.
Garage Queen R6
Is it a pretty big nut? perhaps a 32mm? If so, then ive got a feeling its your front sprocket nut. Since there's a recall on the nut and bend washer, you can probably take the bike to the dealer and get it replaced for no charge. You might want to inspect the chain and front sprocket for damage.
Well just tore her apart to see if that was where it went and sure enough looks like it came loose and ended up in the chain then sitting on the swingarm.
Guess I'm going to have to check out the recall on this one.
Powerban thanks for your help my man! :thumbup
