I would start with 6mm and go from there. I think 12mm you might run into some clearance problems. That and it will be very twitchy.
riverrat said:Dude, you gotta lower the front of the bike about 1cm if you want the same quickness of turn-in as you had before with the 60 profile. Otherwise the bike will turn slightly slower. So the fork tubes come up through the triple clamp. 70 series have a little more sidewall for grip when you are leaned over.
Same here, didn't do anything. No ill effects noticedFailureByDesign said:I switched to a 70 series on my 04 and haven't done shit to the suspension and forks, and works like a champ, no clearence and it kicks ass on the track for turn in speed
I agree. I made the switch to a 70 on my 2000 R6 and noticed only a slightly slower turn-in speed. It was never a problem on the track so you shouldn't worry about it. :thumbupFailureByDesign said:where are you pulling this out of about turn in speed? i switched to a 70 series on my 04 and haven't done shit to the suspension and forks, and works like a champ, no clearence and it kicks ass on the track for turn in speed
