So fuel pump works outside the tank when all hooked up, when I install it into tank and put gas it doesn’t work, but while being out of tank I poured gas into the pump and bike fire up? Any help would be nice
So similar to me, needed to re wire the green connector, the wire inside snapped, I picked up a 2004 r6 with 23.9k miles on it, whoever had it before me had not a clue what they were doing re did the entire bike how did we post pictures it’s prettt sweetHi, I recently went through this. drove me nuts. I eliminated the connectors, both inside the pump canister and on the harness. I found the fuel pump will torque as it starts and the connectors get loose. They are actually pretty poor quality. Bike runs strong now. I ran the wires through holes that I drilled where the connectors go and sealed with marine epoxy.
