nobody?
I sold the PCIII cuz I got rid of my other stuff that I thought required me to have it.... turns out that I don't like aftermarket exhausts and a PCIII on its own makes only a tiny bit of difference on a 2005 and costs me more than I want in terms of fuel economy. So I got rid of it.blackonwhite99r6 said:Why would you sell your power commander? If you researched it then dont be afraid to pioneer that shit, I personally don't know enough about them to give you an educated opinion, but if they are supposed to then im guessing they probably do, tell us what the down sides are after you get em.
Interesting... my guess is that it is a custom map issue. I bet if your PCIII would have worked, you would have made it happen.twinn-burner said:I did a dyno run on pump gas 93, bmc race air filter,superflare stacks,m4 full...=106HP. I was there to get a custom map but my PCIII appears to be defective or at least that is what the tuner states. I sent the PCIII back to dyno jet just waiting to get the results. He showed me another graph of a 05 r6 that put out 109HP that was after his dyno tuning. Not exactly sure what other mods his bike had but I know it did not have the superlflare stacks.....EVen though I was only 3hp down up top.....his bike had mine bike like 8HP from 9k all the way untill the very top.......The tuner does not seem to be real optomistic about the superflare stacks......but, we will see when I get the PCIII and get the custom map....I have a 05 r6! Too bad I already threw the stock stacks in the trash!!! LOL
Well, since my PCIII is gone, do you think it would add much to my smoothness and throttle response if I did just an ignition advance? What if I did the superflare stacks and an ignition advance.... would that improve my smoothness and throttle response on my 2005??CephasGT said:If you want smooth throttle response, do an ignition advance and slide stops. But with the slide stops, you WILL need a PCIII, and probably a custom map to get it really right. And if you're going to do all that, you might as well go with a BMC filter and the Superflare stacks as well. At least, that's what I did, and MAN what a difference.
I was under the idea that the ignition advancer didn't require a tune... is that not correct?CephasGT said:If you're not going to do any tuning, you may as well not do the mods at all. Make sure your chain slack is set right and concentrate on throttle control, and leave the bike stock. I don't mean to sound like a jerk, but some of this stuff is only going to go badly if you do it half-way.
As for smooth throttle response, I have to say the best mod I did was the Slide Stops, but you definitely have to have a PCIII for that.
how's your fuel economy in the city? Is your PCIII map much richer than a "zero map"?brandonncr6 said:I put superflare vstacks, bmc race filter, slip on jardine exhaust, slide stops and a pc3 with a custom map its at 110 hp right now on a 05 r6 but the map still needs some tweaking i work at a motorcycle shop with a dyno so he does a lil bit at a time when i find dead spots so im hoping for 111 to 112 hp with the rest of tweaking
I was going for the stacks and advance, but I thought the BMC race filter needed a PCIII for sure... was I wrong on that one?hesaves0211 said:ok bro you need to man up and accept the fact you shouldnt have ever got rid of your pc3 and youll need to buy one soon enough. like any tuner here your gonna spend dollar after dollar to squeeze out every ounce of power. but you seriously think your feel the diff between 1-2hp esp wo a pc3 with or wo a custom map?! cmon dude! go buy a suzuki haha! no really hit up your bike with a dose of v-stack, ign adv and bmc race filter (and dont worry about a pc3!). but by all means do yourself a favor and buy the pc3, you know you want to.
Yeah, that's what I figured... I am iffy on that one too.CephasGT said:Mmm, probably not. The BMC filter flows a LOT better than the stock one... But the stock map is rich anyway, so you might be alright, I don't know.
