Hi, I'm from Argentina and I have a problem with a 2002 r6.
Since I bought it when it warms up, it becomes very unstable and the engine stops.
I took her to the service and they left her worse than she was.
so I decided to put my hand as I understand something
start regulating valves, disassemble and clean the carburettors and set the vacuum gauges to regulate them.
Now the bike works oscillating at bad idle but it does not stop until it reaches about 70/80 degrees celcius and then it gets so uneven that it stops and has a hard time starting in hot.
Help please!!!
If you can get a cam into the barrels take out the plugs and check the liners the 99-02 are known for liner issues. Check that before you spend hours of time and money on the wrong issue.
