Sounds normal. The pads have to rub the disk slightly, if not the lever would have to travel way to far to get any braking power. Pad compounds these days will squeak a little, it's ok as long as there is materal there and there is no grinding noise. If it bothers you remove the cailpers and clean them, take some rough sand paper and scuff up the pads to remove any glazing.
