dont ground it with the key on....ground it, turn your bike on..if your neutal light comes on..(no matter what gear your on) you grounded it right...if nothing happens pick a better grounding spot
Faster Integra said:dont ground it with the key on....ground it, turn your bike on..if your neutal light comes on..(no matter what gear your on) you grounded it right...if nothing happens pick a better grounding spot
no sometimes its easier for the bike to engage while its rolling such as when your down shifting coming to a stop. find the clutches area of engagement and try to shift into neutral while rolling or rocking the bike. maybe hes just panicing, the oil may need to be changed as well.Faster Integra said:isnt that push starting it? even if it did start, which im guessing it wont, as soon as he went to shift back into neutal it would die..
Firetire said:no. I'm sure he can feel neutral, it isn't that hard to get the bike into neutral. In addition he can't start it with the clutch in. So its an electrical problem, not a mechanical problem.
Replace the relay.
Yh8mE said:I guess so but when i tried gounding the neutral wire the display (the speedometer and rpm guage) shut off and when i take the wire from ground it comes back on is that something normal if the nuetral safety switch is bad?????
What was it?Yh8mE said:i have fixed the pob everything is ok
DreamNofR1 said:Can someone inform me why you would want a remote start on a bike? I am not being a smartass, I can't figure it out....
-Tony V- said:What was it?
My guages are out for some reason....what did you do to fix it?
Yh8mE said:Do you have anything extra installed on the bike? Did it stop working just all of a sudden?????
Where is the saftey switch?I tried grounding the neutral safety switch but when i did the display went off like i took the key out and when i ungrounded it it was like i just turn the key on:sick
