1 - 7 of 7 Posts
R6-Rider
hey guyz n galz had a small off a few days ago and was just wondering if anyone has repaired any paint like this before ???
red had gone through to black so not sure if touch up paint will cover it?
do I need to leave it to the pro's?? I hope not I cant afford it...lol
any way here is the pic....
p.s
R&G's rule...
saved my whole fairing if not bike!!
that can be repaired very easily BUT you'll probably have to repaint the upper.
Gossamer has MOJO!!!
yip...sand, fill, sand, feather edge, primner and then it needs to be painted. You could get some colorite and probably match it pretty good. You really want to take your time withthe prep work and repair though.
1. go to Home Depot or Lowes and get some ABS cement ($3.00). use masking tape and mask off the rashed area. apply the ABS cement on, wait about 20-30 secs then pull the tape off. the cement should stay right in the rashed area. sand/shape from there.
i had rashed my upper in the same spot and you can even tell now.
Resident A-Hole
me 3. mines not as bad either. i think ima sand down my upper and repaint it. im on a mission to fix my bike for under $300. muahaha.
if your plastic comes out half as good as that polished mid pipe you'll end up spending around $63 bucks :lol
1 - 7 of 7 Posts
