1 - 9 of 9 Posts
My manual for the 99 r6 says to use 15w40, but I found some 0w40 synthetic I might wanna try out. I've been doing some research on oils and the first number really doesn't mean much as it's just how light the oil is. So in theory wouldn't a 0w40 oil protect more because it's lighter and will run through the engine easier on start up, at running temp it's all the same anyways at 40. I also hear people racing with 0w40 for increase hp and better mileage? Any thoughts?
Gossamer has MOJO!!!
it could increase hp slightly but oil pressure may drop. I would stick with what the manual says for your climate area
^+1 the first gen's are so finicky with oil that you are better off sticking with either 10w or 15w.
right now im using 10 weight oil and that has worked for me. no need to use the 0 weight if you are not racing, and the said mileage increase is not noticeable at all.
i have been consistently getting 43-48 mpg with th 10w, and the occasional 30mpg when i ride WOT :lol
Ive been using 0w40 for about a year now since I replaced the trans. I have no complaints, bike shifts great, operating temp is better, easier starts as well. Just went to the track for the first time this past weekend and have no complaints.
www.frontiercycle.com
i hope you mean you are using something like 10W40...the first number isnt the weight. the first is what the equivalent oil weigh would be in a cold start(the w stands for winter...cold conditions)...the second number is what the weight is at operating temperature. basically, what that means is that the oil will actually thicken up as it gets hotter. in a 10w40, when you start it in the cold, instead of it being a straight 40 weight, it has the viscosity of a 10 weight oil, but then as it gets to operating temperature, it has the viscosity of a 40 weight oil.
10 weight oil would be WAY too thin at operating temperatures.
It is a 40 weight at operating temp, 210 degrees and a 0 wgt at 32 degrees f
No Difference at qperating temp.
Very good...
Bob
Thanks for making this CLEAR... Most common mistake people make is thinking the first number is the weight.
In all actuallity, it IS the weight (viscosity)of the oil at approximately 32 degrees.
The oil does not thicken to become a 40 weight. It is 2 different test procedures and the hot viscosity is always checked at 210 degrees F.
The Best isn't cheap
Cheap isn't The Best
Bob
1 - 9 of 9 Posts
