anyone?
YOU DO NEED TO SPLIT THE CASE to replace the gears, there is no other way to get to them out.aws140 said:i went to the yamaha dealer in seneca, sc today to get a new front tire. while i was there i asked them about the tranny issue and they were just totally out of teh clue. i told them about the problem with the digs and all and they just acted lik ei didnt know hwat the hell i was talking about. they quoted me $878 in labor to fix, and kept saying the cases have to be seperated but i kept trying to tell them they didnt have to be. to top it off, when i got home i realized the dumbasses had put my tire on backwards. it was too ate to call them back, but theyll be hearing from me tomorrow
well in the how to in the how to section the 2nd gear in replaced without splitting the case. there are pictures to prove it. digs was a typing error, i said dogs when i was talking to them. im just going to talk to local shops and see what they say. i just dont want to buy an 03 tranny and it not work. thats why im trying to find some info on here about it but i have had no help with itD duck said:YOU DO NEED TO SPLIT THE CASE to replace the gears, there is no other way to get to them out.
The tranny issue isnt as wide spread as the internet would lead you believe, it only happens if you grind the gears. And its gear dogs, not digs.
They probably looked at you like you didnt know what you were talking about because you most likely thats what you sounded like.
You might want to re-read the how to...aws140 said:well in the how to in the how to section the 2nd gear in replaced without splitting the case. there are pictures to prove it. digs was a typing error, i said dogs when i was talking to them. im just going to talk to local shops and see what they say. i just dont want to buy an 03 tranny and it not work. thats why im trying to find some info on here about it but i have had no help with it
http://www.r6messagenet.com/forums/showthread.php?t=82595
theres a link to the how to
Now it is time to separate the men from the boys. The next step will be to remove the lower engine cover. Remove the metal radiator hose from the front of the engine, you should be able to see that it will get in the way once you start to separate the lower engine half. Double check to make sure that all the covers and parts on the engine will break away freely once the lower cover is removed. Remove the oil strainer thingy, the oil pickup line, the C-shaped oil hose, oil pump strocket cover, and the oil pump. Most of these are easy, for the oil pump I had to stick an allen wrench into the bolt hole and twist the dowel out so that I could detach the chain from the sprocket. Sorry I was too dirty to get pictures of this...but is self explainitory.
I helped someone replace the gears in his tranny to fix the 2nd gear issue and I can tell you that the cases need to be split.aws140 said:well in the how to in the how to section the 2nd gear in replaced without splitting the case. there are pictures to prove it. digs was a typing error, i said dogs when i was talking to them. im just going to talk to local shops and see what they say. i just dont want to buy an 03 tranny and it not work. thats why im trying to find some info on here about it but i have had no help with it
It dosent prevent the issue, but it does help.elusive said:Can't you undercut either the gear or the dogs (using 02 parts) to prevent another tranny issue?
