try searching for this b/c i remember seeing a sticky about this. There is some sort of vibration damper on the front sprocket to alleve this??trubluR6 said:I just installed a new Vortex 15 front and 48 rear and a DID chain. Now it's makin this loud ass annoying noise. Can i fix that? I fit the front sprocket in so that the bigger lip was to the outside.
the front sprocket is now smaller if you’re doing -1 compared to the OEM sprocket , this changes the angle of the chain. so now the front part of the chain rubs / wears harshly against the upper hard plastic chain runner. this will be the really loud whining nose. the front sprocket will make more noise compared to the OEM which has the rubber damping either side. also obviously too tight would have make it noisy. but i did this conversation last week and the noise is louder than my race can with no baffles which is ridiculous. today i took a look at the chain runner and clearly you can see its contacting / wearing on the front of the upper runner (see pic). so i used a flexible dremel tool to get in there and cut it away. problem solved. (you can even see where the chain lube is gathering due to it contacting harshly and its worn down..) thats explains the very loud whining noise.I just installed a new Vortex 15 front and 48 rear and a DID chain. Now it's makin this loud ass annoying noise. Can i fix that? I fit the front sprocket in so that the bigger lip was to the outside.
