1 - 7 of 7 Posts
The front is the same part number, and bolts right up. The rear is a different size, and wouldn't work with out changing some stuff around.
Hi , How are ya
Wrong same wheel 99-02 are the same 03 is when they changed
No, you're wrong... 99 R1 front wheels will fit a 99-02 R6, but the rear wheel is 6" wide... too wide for an R6 swingarm.
Huh?
98-01 (and maybe 02) R1 front wheels are a direct swap to 99-02 R6 front forks with no modification needed. Wheels, bearings, spacers and even the axle is the same.
As Thrak said, the R1 rear wheels are 6" wide and you would need to do a good bit of work to fit it to a R6 swingarm.
1 - 7 of 7 Posts
