1 - 20 of 64 Posts
1. new tires
2. aftermarket front rotors
3. front SS brake lines
4. aftermarket brake pads
5. steering damper
What are your top 5 most significant upgrades, starting from the most one.
1. lightweight wheels
2. lightweight wheels
3. lightweight wheels
4. lightweight wheels
5. lightweight wheels
they're that good that i forget everything else! :wink
Stock Tiip ARIO!
1.Aka full racing exhaust mounted at middle point 2.Gold shortie's 3 sliders everywhere 4 ZG DB Green Screen-one Fuk monster
1. Tires
2. SS braided brake lines
3. Steering damper
4. Rearsets
5. brake pads
How can tires be a mod? That's like saying putting gas in the bike is a 'mod'... Or changing to synthetic oil is a 'mod'...
Gixxer rider
1. 520 conversion -1 +2 regearing
2. SS Brake Lines
3. Hyperpro steering damper
4. GP shift with Sato rearsets
5. Exhaust
waiting for GP
Id say from a performance perspective (excluding the slip on at #5)
1. Stainless brake lines -Galfer
2. steering damper -Ohlins
3. tires -Michelin Pilot Powers-
4. 520 conversion w/gearing change -DID ERV3/AFAM
5. exhaust -Jardine s/o, not really performance but I had to have it
I think tires are a mod. If you took a bone stock bike of the showroom floor with 208's on there, put some laps on it, then threw pilot powers or diablo corsas on it and did some more laps you would definietly pick up some time.
If tires aren't a mod, then a 520 sprocket conversion isn't a mod...all you're doing is replacing stock parts :myfault
Considering all that's touching the road are two small rubber patches, I'd say tires are one of the most important modifications you can make.
whats the 1/4 turn thorttle?
You call it a 'mod' if you want... At 3 - 4 sets in ~ 1K miles, I call them consumables...
waiting for GP
if the tire you switch to and "consume" is a higher performance tire.............its a modification, you seem to be the ONLY one that feels this way, if you wear out a pair of the Dunlop 218s and replace them with 218s then yes you are correct.
1 - 20 of 64 Posts
