Hello I just bought a used R6 and I’ve noticed that when you start up the bike and rev it a little it will come down slightly and stay revved around 3-4000RPM. The bike starts up and runs around 2000RPM and idle is kindof up and down until it warms up then evens out at still 2000RPM. If you switch it off when the RPM is still up and then go to restart it it will still be at the revved
The cables for the throttle are new and lubed, does not seem to be any binding in the cables, the throttle itself is free. Cats have been removed and the O2 sensor needs to have a resister installed from what I readto get rid of the check engine light.
Any help on what to check would be greatly appreciated.
What year bike might be a "little" helpful but it most likely sounds like you just need to adjust your "cold idle" so it's not so high
