Hello all,
2005 radiator with less than 4k miles bubbling halfway down and leaking. When bike warms up, leak stops. When I come back to the bike with fairings off, I see the spot on the floor.
I want to replace the radiator but I only find 2003-2004 and 2006-2009 rs6 replacement radiators listed. The 2005 one I found is 4x the price. My understand is that the 05 radiator is different due to the two fans... can someone confirm the older 2003-2004 radiator won’t fit. Thanks in advance.
im having the same issue i cant find a 2005 anywhere how ever 03-04 should fit as the r6s goes from 03- 09 and they are essentially the same bike i might be wrong but i have a 03-04/09 r6 and r6s on the way ill keep u posted on the fitment
The whole deltabox frame parts are compatible. This includes an 03-05 r6 and the 06-09 r6s. The only differences between the 04 and 05 are forks, t bodies and I believe the rotors are slightly different. Keep in mind not all r6s and r6 parts are the same though, I did a bottom crank replacement on a 07 r6s before with an 04 lower crank and actually the tolerances were so different the crank was friction locked when torqued down
