Recently picked up an 05 r6 and it kept dying on me. The battery wouldn't stay charged. I had gotten the battery tested and it came back fine. I ended up cutting roughly 2" off the rectifier wires and using connectors to plug it up. Rode for 10 hours yesterday, and then the bike completely killed on power. Lights don't work, dash won't work, ignition, etc. I checked all the fuses, the ignition fuse popped. Replaced it and still nothing. Starter relay doesn't seem to be compromised, and the relays look ok from a visual check. Picking up a voltmeter soon to start running tests. If anyone has any ideas or a wiring diagram, that would be great. My current assumption is maybe either a bad recitifier or bad ignition switch?
Discussion Starter · #2 ·
Update: The battery with key on comes back with 2v, unless I pull the 40amp fuse on the starter relay. With that pulled, it'll read 13v. Would this narrow my issue down to the starter relay? And could the starter relay cause the bike to also not have any power at the ignition switch, dash, lights, etc?
Yet another update, I ended up deducing that my battery had gone bad. Borrowed a battery from a friend and now my electronics work again and the bike will crank. Unfortunately, I'm also now getting codes: er_1 and er_2. Both relate to an insufficient outgoing ecu signal. I'm beyond lost now. Bike will crank, but eventually die down. Starter relay clicks with a key turn and buzzes when it gives up on cranking.
Hi, I’m new to this forum. I have an issue. I did a stupid mistake, left the bike running idle for more than 8hours (by mistake - forgot it on) and when I went to check it found out that the bike won’t start or gauge won’t react upon turning the key. The only thing that is switching on is the middle light.
Could it be the main fuse the cause ?
Yamaha R6
Your Bike might have stalled but the power stayed on, your battery may need to be recharged: try this first!
Yamaha R6
How did you get on in the end?
