Newbie banging his head against a wall !!!!!! Hi I am trying to fit a Gripone traction control unit to my bike,it has a plug and play loom. You unplug a coil plug the main loom into the TC loom and then back onto the coil. The unit takes its power from the coil. It does not work,after checking the voltage to the coils,I am getting approx 5.5 volts.various garages/dealers say it should be a 12v feed to the coils and the ecu switches to ground when it’s ready to spark. Is this correct?
My question is,should there be 12volts constant feed when ignition is on. When I test the voltage with engine running the voltage goes up to roughly 18volts. My bike runs fine,I was just wondering if my bike had a problem or not. If not I’ve wasted £££ as the unit was second hand. I have had the unit checked and it is ok.
Any help would be much appreciated
