Hi everyone,
2003 R6
30K miles. All stock.
I may have a charging issue. After hard running, the motor's idling becomes pretty erratic with rpm going up and down between 800rpm and 1500rpm and sometimes headlights flickers.
I measured the battery voltage while at 5000rpm and it reads 12.71. When idling it also reads 12.70 or 71. Figures might be different depending on the charge level of the battery but whenever I test the battery voltage, the voltage at 5000 rpm and idle were very similar.
I already have replaced R/R and stator and the battery is a little more than 500 miles old. What else could be causing this issue?
2003 R6
