Hello I have a 2000 r6 with 34 000km and when I start out the bike bogs. Huge for about 5-10 min will not go over 8km/per hour
Eventually it kicks in and drives fine my bike has a k and n filter yoshi pipe and jetted and thoughts the yamaha dealer says it might be
The tps sensor
Any ideas ? Please help
Thanks corey
and to add
well heres the other kicker,
I do let the bike warm up to operating temps.
and this happens all the time, intermittinly, usually the bike will rev at 3,000 rpm when i have the clutch in netural, as i ease the clutch, the bikes goes back to 1500rpm.
and if i start out on a incline the bikes usually bogs under load.
i talked to the yamaha tech that worked on the bike for the past owner, and he also said the tps reads proper. and i ask if the carbs were serviced.
he also said that the number 1 cyclinder might have a 40% blow by( i have a good mechinac friend that will confirm that)
Please please help.
thanks again
corey
`99 R6 owner
did you do a compression test?. do you smell or see any gas leaking out of the carbs?. cause i have a 1999 with a similar problem. but mine does it when i go over 60/70mph. check the engine oil for any gas mixed with the oil.
I have the same problem on my '00 model, mine happens till 2k revs, then its fine right thru, but its more exaggerated when its cold.
Did a full service, oil, oil filter, plugs, fuel filter and carb sync.....and the problem's still there.
Please lemme know if you guys make any head way with your problems.
Fabian
I’m Having the same prob. Just bought a 2000 R6 and the bike Lags big time under load. If pull the clutch and build up revs it just dies till I pull the clutch and rev it up. But all I’m doing is coasting off the revs I just built. It’s driving my insane. Hope it’s an easy fix
