I’ve got two first gen R6’s. The 2000 runs great but currently has a salvage title and will need an inspection before I can put it on the road. It also has been messed with a fair bit (2005 fork swap, swing arm extensions, a lot of hacking at the harness). The 2002 is much more original and has a clean title, but the chain snapped and took a bite out of the case.
I think the easiest fix for now is to make one good bike bike by swapping the 2000 engine into the ‘02. If I go that route, my question is: do I need to keep the engines with their original ecu’s (and harnesses) or will either combination work?
Thanks
